Engine/Transmission (1998.5 - 2002) B&M Transpan
2nd Gen Non-Engine/Transmission Electrical Help
Engine/Transmission (1998.5 - 2002) 99 transmission temp
I am going to put on a double deep B&M trans pan that holds an extra gallon of fluid I was wondering if anyone has used this pan. It is a 727/518 pan and comes with two spacers for the filter. I am assuming I will use the 518 spacer but will measure the clearance between the stock pan and filter and double check if the new pan will have similiar clearances. Trans pan The 10280 is what I have.
Mine only holds 2 more quarts than stock...
