Three of us met in the Republic of Vermont for a day of injector upgrades
, two 2K's and my 99, one Auto two 5spds all 4x4, all 3. 54.
Each of us already had a VA, two had boost elbows one of those had a functioning regulator style boost module(Articat) and one has a 4" exhaust(Mopar Muscle).
The day ended with all three with boost elbows, two with 275injectors, one with DDstageI's(me!), one has an un-installed DD boost module and the third has the parts for a regulator style boost module.
In addition, one went home with a nice greeting card from the Vermont state police
, trooper having said something about speeding several times in front of a trooper's home being like "farting in church"...
I have the Stage I's and can report that they do blow a little smoke when you stand on them. (OK with me)
I did a few test runs against the auto w275's and the 4" exhaust (MoparMuscle) and generally felt like mine was stronger. These were 70 to #censored# runs on the interstate. The last pass he seemed a tad stronger so I wonder if he kept the truck out of overdrive on that one? Neither were using any form of boost module but do have boost elbows and the VA.
Real world impressions: My truck is starting just fine when cold. I thought the idle was hunting a bit yesterday but don't notice it today (maybe air?). The cruise control seems to be fine on both the 275 and Stage I's. The part number on my Stage I's matched the OEM injectors exactly, kind of adding to the stealth of the VA... This is no HVAC, but I am honestly not trying to get that much HP (yet). I am now seeing acceleration from 70 on hills that were not showing much in the past. (clearly more juice available). The HP across the board is stronger. On the winding secondary roads last night I kept finding myself way below 40 in 5th because I did not sense the bogging that normally tells me to downshift. I can see I will have to re-learn the feel of the engine so I don't forget to shift. The top end just goes and goes and goes even without the boost module installed. When upshifting from a stoplight in normal driving, The truck is much snappier and I keep hitting the redline before I realize it. With the LS rearend, it is easy to break traction with this thing. I did it several times as I shot down an on-ramp last night upshifting all the way.
Bottom line, WAY COOL!!
Was it worth the extra money to go from 275's to Stage I's? If you have the mad money, yes. If you don't, you will be happy with the 275's as long as you stay out of way more powerful trucks.
If you have a VA and want more power, do the cheap boost elbow before you do anything else. It unleashes power that is hiding behind the OEM wastegate setting. VA should include these since the $7 part makes a world of difference (at least it did for me).
I need to do the exhaust and get the gauges in before I plug the boost module in.
Green Monster's cyber garage (and TDR multimedia sandbox)
Yahoo messenger: davidc3y
