VStahl said:
I bought my B & w gooseneck hitch today and will be installing it when it arrives, are their any helpful hints on the install? Any tricks that can help me with the install?
Read the instructions twice. No, the pix aren't from a 3rd gen but everything still will work.
For lots of working room, jack the rear up and take the wheels off. Otherwise, just jack the rear up and let the wheels hang.
Remove your wheel well liners.
A 3" hole saw works for the access hole for the lever thingy.
Chase all the threaded holes with a tap and use a little grease to aid installation.
No, you can't cheat it rearwards to gain a little bit more cab clearance. The frame really doesn't allow it.
The wiring harness move is just like they say, just be patient with getting the clip out of the frame.
Measure 3 times and cut once for the big hole. Drill a pilot hole first. A healthy 1/2" drill motor with a featherable trigger is a must.
There are two sets of holes to install the safety chain hooks. Use the ones that line up with the lower part of the bed. That way, they won't stick up and you can slide in flat things without obstruction.
Remove the filings right away or the rust from them will stay in the spray on bedliner for a long time.
Use your son/daughter/wife to help lift it in place from above. Yes, they have to hold it long enough to get two bolts started. Tell them to stop whining, you will have the bolts in after you remove the dirt clod from your eyeball.
Install the hooky things in the frame holes before tightening the two bolts for its bracket. Yes, you can coax it in later with a hammer.
Retorque wheels after putting them back on. 135 ft lbs.
Don't do a burnout with untorqued wheels.
