Back fire????
What rear end ratio?
Drilling EGT & which Boost bolt
I dont know if it was a backfire. I was driving into work this morning and was passing sombody let off throttle and KABOOM!!!!! sounded like a grenade went off under truck no cel truck seems to be running fine I have almost 8000miles on it never any trouble anbody have any ideas. thought I blew the dpf right out the back of the truck guess that is one way to get rid of it ????????????????????????????. :confused:
The common rail injectors are fired by electronic pulses. If you have a box or if something is interfering with the timing of the injectors, they will fire at the wrong time and cause the 'backfire' sound.
