I posed the question today to cummins, is there a minimum back pressure needed for the diesel engine? I know my gas rams did not like having little back pressure, my low-end torque suffered greatly! But what about the diesel? I have run it both with and with out the muffler and it seems to run better with the muffler although this may be a mind over matter thing. Does the truck seem to run better because the back pressure is there and not allowing the boost to drop as fast as I manually change my gears or does the back pressure actually help with torque. The most information Cummins gave me was "Cummins, Inc. is not in a position to advise the effects of removing Dodge exhaust system components, such as mufflers, pipes, silencer rings, etc. We have discussed exhaust system size with several Dodge customers and advised that Cummins recommends that exhaust restriction be limited to 4. 0 in-Hg and the chassis builders are expected to engineer their exhaust systems to this recommendation.
We have been told that going to a larger 3 1/2 or 4 inch exhaust or a 'mandrel bent' 3 inch exhaust will reduce restriction of the stock Dodge exhaust. Reducing restriction is fine and may make the engine perform even better, but it does not increase horsepower. "
So how about it folks, lend me your thoughts,
Bob Ballard
My web page
Bob Ballard
My web page
