Back up camera blury
Need help with part number
Red Lightning bolt
JFK
On my 2015 Big Horn, the factory installed back up camera mounted in the the tail gate produces a blurred image on the screen. The lens is clean & unbroken, electrical connections for the tail gate assembly are clean & dry (at both the body harness to the tail gate and the connection within tailgate). I was able to remove the camera and visually inspect it but did not see anything obvious. Suggestions? Thanks, Jim.
Next step would be to check the connections in dash and at radio. If those check out, sounds like the camera itself has an issue.
Probably the cam itself.
Connection, I don't think so, either you have a picture or you have non, but blurry points to the lens system of the cam.
My 2012 Durango has a cam problem too always in wet conditions.
Want to thank every one for their input. I'm going to replace the camera,,,,,,,if I can get one at dealership. Jim
