HI,
I'll have to say, for something as simple as an exhaust brake is in operation, the major manufacturers sure charge a lot for them (especially the ones that are simply on and off switch controlled... . The fancy ones that integrate with auto trannys etc..... those I can see being bigger $$ because of all the electronics involved... )
I do like this thread because it gave me the idea about possibly saving some $$ on a exhaust brake build BUT as mentioned earlier it would be nice NOT to have to START with parts from an expensive kit ... .
Although possibly crude, can a back yard mechanic Build the Pipe/Butterfly assy
from say a section of 4" or 5" exhaust piping and maybe cutting a disc out of some readily available material and essentially making the high $$ stuff for less?.
I would think a true home brew system would be easier to make as a downstream install rather than one that hangs off the turbo (for the simple fact that he assy can be cut off a straight section of exhaust or thick pipe).
Also, not sure if it can be done BUT how about using an air can off a big truck airbrake and using it in reverse (i. e. vacuume operated instead of air operated to save $$ by not having to get an air compressor) to actuate the butterfly assy?
Is this practical or possible?
Another thing I would like to see, and it would probably be easier to do with a "stepper" motor controlling the butterfly) would be to see a brake that can be varied as to braking power... . NOT a simple on/off.
Personally I have never used a brake before BUT it would seem to be a pain to have a super good brake and have to turn it on / off to maintain a reasonable speed on a grade (I say this because if a brake is really good, it will slow the vehicle perhaps more than is needed to keep a reasonable speed)... . Hene the stepper motor version... . Dial in the amount of retarding you need for a long constant grade... . Heck if you want to get fancy hook it up to a cruise control type setup only in this case the the exhaust brake is manipulated to hold speed... .
I believe this can be accomplished by the stepper motor controlling the butterfly in small increments rather than making it an on/off proposition
Any tinkerers out there that has done something like that?
Oh I suppose a turbo blow off wastegate can be used to max out pressure at 60 PSI which seems to be the goal as far as backpressure is concerned (hmmm here we go back to factory made stuff!)
Thanks!
Andrew
