Has anyone tried to run the engine without a LP by bypassing in tank pump? Just curious as it would be easy if in tank pump failed to connect fuel to 2 micron filter in engine compartment with a spare 3/8" feed hose from tank or a small tank of fuel in bed of truck, etc. Some mention the in tank pumps are getting better and they only cost around $120 at online Dodge OEM discount places. Found under Fuel system, Diesel, Fuel pump in Collision area. Any 05/06 out there with failed in tank pump at low miles not related to junk in the tank?
If pump died I would, ideally, connect input of 2 micron aftermarket filter to capped 3/8 fuel line routed to engine compartment after sucking on it to prime.
