Engine/Transmission (1998.5 - 2002) bad ait ?
2nd Gen Non-Engine/Transmission Thermocouples??????
Engine/Transmission (1994 - 1998) Valve Covers Leaking
bad iat ? im flashing all these codes and thay are 1594 o500 1693 0216 . if i have a bad iat sensor would thay play a role in these codes?
TDR OBDII List
P0216
Fuel Injection Pump Timing Failure
This is a bad one, ominus of a VP44 failure
P0500
No Vehicle Speed Sensor Signal
What is says, or you have spun your rear wheels at some point
P1594
Charging System Voltage Too High
What is says?
P1693
DTC Detected In ECM Or PCM
Ignore this one, ussualy comes with other codes
Nothing there points to a IAT problem as far as I can tell.
Jim
