When it gets really cold (like lower teens and below) my starter grinds the first time you activate it. It grinds on the flywheel i'm assuming. Then the next time you hit it, it'll catch and crank. when it's REALLY cold, then it does the above, but when it catches it'll only turn the engine over a turn or two then kick out half way and grind some more. This gets very frustrating. I don't know what is wrong. Something with my starter? Bad solenoid and plunger??
This morning it didn't do that. Just typical cold diesel behavior... turned over for about 4 seconds, fired a cylinder, got caught on a compression stroke, turned over a couple more times then crawled to life... . there was so much smoke I couldn't see the car next to mine!!! that was neat... hehehe Oo.
The grid heaters cycles preheat, but no post heat... crazy
Any idea?! THanks!!!
jaynes
jaynes
