Bit of history first..... truck was making a fuel rattle when leaving from a stop and most times on tip in acceleration. Heard from many that FCA is a common problem for this concern, was making plans to get it done. Before I could replace it I did a really hard run on the truck, full throttle to way over legal highway speeds. Once I coasted down, the truck was running rough and chugging at lower speeds, higher speeds seemed ok. Did some preliminary checks, replaced injectors and FCA, truck now runs smooth again, but over idle it has a bad fuel knock and blue smoke. With a quick snap of the throttle, rail pressure goes to over 20000 psi. Truck is sitting at a friends shop right now. Hope someone has a suggestion on where to go from here.
Thanks
Thanks
