I can't figure out if I've lost the lift pump. Saturday, pressure was good. I stopped for fuel. Topped it off. Took off down the road, I glanced at the gauge, and to my unpleasant surprise, 0psi. The readings are taken at the schrader valve. Within minutes The gauge was reading around 5psi. At idle, it would show about 10. My pressures have always been 15psi at idle, and around 8 or9 full throttle. The truck never missed a beat. I was away from home pulling my boat. The truck runs awesome. It started right up this morning. I even bumped the stater to see if I could hear the pump running, and it does. I put a new fuel filter in, and still very low pressure. Also, when i stopped for fuel again, I drained the fuel filter, Cycled the lift pump a couple of times, and the truck started right up. I'm kind of confused, any advice greatly apperciated.
Thanks
Big A
Thanks
Big A
