I had previously posted that my lift pump was bad as I had suspected, and also been told by a Cummins tech guy when I told him my symptoms over the phone. I have since spoken with another diesel shop in town, and the guy there says that it's probably my VP44's and it's internal diaphram being blown out. Now, I hope he's wrong, but I thought I may be able to get another opinion on here. Here's what's going on:
I have a 2002 ETH, w/ DDIII's and a Drag Comp, with Wildcat banjo bolts, and an otherwise stock fuel system. I was driving WOT last week, when all of a sudden my truck stalled out. I played with it for a while, and it would not start back up. It acted like it was out of fuel, I think. I had plenty of fuel in the tank though. I finally got it started again, barely, and since then, I have been runnning about 3psi lower than normal for fuel pressure, and the pressure drops significantly, very quickly, when I accellerate at all. With the drag comp on, I can suck the pressure almost down to nothing now (so I have kept it off since then), and I speculated that I DID suck it down to nothing when it stalled (which would explain feeling like I ran it out of fuel. I have never had this problem before, and have always maintained at least about 7psi of pressure at WOT, and about 14-15 at idle.
It is still drivable, but something is not working correctly, and I am worried about doing more damage if something IS out.
Any ideas?
Thanks.
-Skyler
Any ideas?
Thanks.
-Skyler
