hey all - truck has been doin real good until lately. after i drive it , and park the truck for a while i can look under the front differential, and see a bit of diesel fuel on the ground, (sure it's diesel i took a whif too make sure wasint oil). i got under the truck today and did a major inspaction to find the source of the leak. i didn't find a damn thing! i checked the lever on the fuel filter to make sure it was completely closed, and it was. besides this, the truck hesitates to start alot more in the morning, especially if it is cold. i don't get alot of white smoke, and im pretty sure my timing hasn't slipped because power is good once truck is driven for a while. im starting to lean tworads a lift pump that is starting to head south? i tried to do a seach and get some definative answers but didn't. more than anything i probably need to know where the lift pump is located, so i can check it, and see if it's the culprit. if anyone had some feed back on the issue, id sure like to know. thanks!
-wes
-wes
