Happy New Year!
I started the new year out by ramming my cummins into a concrete pole base. Point of impact, was the driver's side front wheel. Still not sure quite how I managed this. There is no body damage, but the truck was disabled by a broken adjustment sleeve on the steering drag link. The sleeve snapped in half.
Got the truck towed and sleeve replaced, called around got prices from $300-$1600 I went with the$300 which included an alignment.
Shop says all is good, but they aligned it the best they could given the fact that I have a bad ball joint. They said the ball joint is just normal wear and tear and not likely any damage from the impact. I knew the truck was going to need ball joints soon so not terribly alarming. I told them I would hold off for now, this was not a shop I was familiar with.
So I Get the truck back and head down the road and its not aligned. Significant right hand pull and steering wheel is clocked about 20% off to the right. Feeling a bit hosed on an the alignment. So I Call the shop back and they wont do anything until I cough of $1,000 for ball joints. If the ball joint was "So bad" why did they even try to align it, why didn't they call me while they were working on it to say, we can't align it or you've got a blown ball joint? Of course they didn't tell me anything about needing a ball joint until after I showed up asking if the alignment turned up any other potential issues.
Now which ball joints, hate to spend an extra $300-500 on ball joints for Dyna or Carli only to find out something else (steering box, or tie rods etc also have to be replaced. Are Moogs that unreliable. The mechanics I am talking too act like you should easily get 100k out of well maintained greasable moog ball joints. About the same as I have read I would get from Dyna? THoughts? I see several other posts on the issue and lots of happy folks, but not a lot of feedback on folks at or over 100k on carli and/or dyna.
Worth it or Not?
Worth it or Not?
