My 97 has a bad engine miss when i'm out of gear, engine warm, and when i rev it up. It also does this if i excelerate hard in 1st and 2nd gaer. The motor spits and sputters, shoots a cloud of white smoke out the pipe. its to the point now where i can hardly excelerate until i'm in a gear where i can lug it a bit. I did just have the timing set to 17 degrees, and it made the problem worse. its been doing it for a couple years, but hasn't been an issue until i started messing with the pump. Now the more fuel i add the worse it gets. The truck has a #10 plate, 370 injectors, hx-40 with wastegated 16cm housing, and a AFC spring kit. Could use some help with this very annoying problem, is it my governer adjustment, havn't touched that yet. :{
