I have noticed with the cold weather that the upper radiator hose is sucked flat
before I start up in the morning. I don't recall if this was the case in the past or if this is a symptom of something new. Shouldn't the radiator cap allow coolant from the overflow tank to flow back into the system as the engine cools? Is this just a bad radiator cap or is my headlight fluid low?
Mystified in Missouri (but then again, I usually am
