Engine/Transmission (1998.5 - 2002) bad shake
Engine/Transmission (1994 - 1998) Introduction:
can anyone help me with this problem i was doing some good hard runs with my truck it was running great until one time i was hard in a run when it was about to shift every gear (auto) the lever for the transfer case would shake very bad then the whole truck would shake you apart only on hard runs normal driving it is to be ok please help if you can
I would first check all your driveline bolts and then inspect your carrier bearing on the rear driveline ? While you are under there check all the frontend steering components.
Up above take and jack up 1 front tire and see if it has play when you wiggle it and then do the same on the other front wheel... ... ... ... I dont know alot but try this and see.
Cheers, Kevin
