I am experiencing really bad shifting with the engine on, and when start driving- noise and vibrations, like something is loose. I'm afraid of driving it and damaging something.
It all started because 1st and Reverse were a bit hard to get into. It would go, but after 2 try usually. No force, just harder shifting into those gears. Fluid is changed every 30000 miles-either dealer fluid or Pennzoil Syncromesh.
After a lot of researching and talking to people, the opinion I got was- bad pilot bearing. I do get in bad traffic often, so a lot of shifting. There was never any noise or vibrations. Clutch has never slipped. Truck has 108000 miles, I bought it brand new.
Few months back I found a leak inside the cab, coming from where the clutch master cyl. enters the cab. I ordered the SBC hydraulics. It was good when I started the truck, and I thought my problem was solved. But later the shifting was the same.
So- after the research, the pilot bearing diagnose came out.
I decided, after recommendations here, to get the SBC ConO with the upgraded pilot bearing and new flywheel. It's expensive, but I wanted the best, that's why I bought it.
I ordered it and had it installed at a diesel performance shop, specializing in diesel Dodges about an hour drive from me.
After the install the owner drove it from the back of the shop to the front and told me it shifts hard, but "once running shifts fine"
What an answer! I told him I will not drive like that.
I sad it's not good, it was way worse then before.
He said from around 50 SBC they've installed mine was the 3rd with such problems after install- that's a big percentage! He said after another new clutch was installed, it was fine. So, after talking with Peter he's sending new parts to them, so I have to drive and hope to get it fixed. How frustrating. What if something was damaged during the drive home or when I have to go back to them?
So, now I'm suspecting that the new SBC hydraulics are not pushing far enough on the fork to release. Maybe there is trapped air inside. It supposed to be pre-bled, that's what I was told when I ordered it. How do you bleed it?
Sorry for all that. The questions is: Has anybody experienced this after a clutch install, specifically after a SBC ConO with their flywheel and new pilot bearing?
By the way, my OEM clutch was almost like new after 108000 m. The flywheel too, the pilot bearing looks a bit dry, but not damaged, spins fine, all the needles are there. I do not know what it's supposed to look like. All the parts seems perfect. The owner of the shop said-"nothing wrong with any of the parts-they were in very good shape".
Thanks again, and sorry for the emotions. It's just frustrating, that I can not work and have to sit home from last Friday 25 till Tuesday 6. I'm not getting paid, I'm self-employed.
I would like to see if this has happened to anyone and what was the couse.
I'll let you guys know how it turns out.
Ilian
Ilian
