Engine/Transmission (1994 - 1998) Bad tick/knock. big problem i think
Engine/Transmission (1998.5 - 2002) Banjo Bolts/high Flow
Engine/Transmission (1998.5 - 2002) Cracked Block
Just pulled in the driveway after about a 30 mile trip out of town. Got out of truck walked to mailbox and left it running to cool down. I then notice a bad ticking sound. I can usually hear a light ticking noise from drivers door of truck, but it never alarmed me before. this tick/knock is alot louder, and not normal diesel noise. I got underneath and listened, and pinpointed it down to flywheel are. now i did replace clutch recently but i know thats not the problem. I also noticed a hint of engine oil on the bell housing bottom. I do notice that at around 2300 rpm (roughly) that there is a sort of heavy knocking (bottom end), but its not really heavy and its been there since I bought the truck in june. Also this is a twelve valve cummins. Down to brass tacks. I have heard of rear thrust bearing failure, the heavy rear end tick/light knock really has me concerned. This truck is sitting in my driveway, and I am going nowhere until I get an answer from you all. What do you suggest. This is my only vehicle. how easy is it to pull pan? Really Need help. I had this in truck 911 and got zero help, I am going to stick with this (my favorite) forum.
Checked end play, I could only get between 16th and 32nd out of it.
Just a shot in the dark, but have you considered loose bolts on the flywheel and/or the pressure plate??? I had a gas motor make the same noise and it was loose flexplate bolts... . just trying to think positive!!
Problem Solved
Found the problem. not having any endplay had me stumped. I just repaced lift pump so I was like, Naw cant be that..... rriiight. Yeah it is the lift pump. Orielys auto parts strikes again :mad: . I am really really tired of replacing parts three and four times :{ . I have since switched to Napa... the lift pump and the track bar are the only parts left that i got from Orielys. both have to be changed. this is insain. thankfully warranty will cover them both. Oo.
