Hey guys, I haven't posted on here in quite a while but I am needing your knowledge base in the worst way. I have an 04. 5 3500 6spd with 101K miles and I am running 35" Procomp X-Terrains on KMC XD Rockstar rims. I am experiencing really bad vibrations while towing with a 34ft gooseneck trailer, however, I don't experience the vibrations without the trailer when I am driving down the road. I replaced the carrier bearing less than 10k miles ago due to it being completely worn out, and I have checked it, it is fine. I checked the transmission mount by pushing up on the transmission to see if the rubber mounts had any flex and it seems to have a little movement in it. I had the rear ujoints replaced under warranty at 32K miles, so it might be time to replace them again. I am also running air bags at 70lbs when loaded with the gooseneck. When driving down the road you can physically see the transfer case shifter vibrate in a cyclical fashion, meaning, you can feel the vibration for about 5 seconds, then it stops for 2 seconds, then the same pattern happens again. To me, there are only a few things that it could be and should be done in the following order:
1. Balance tires
2. Replace rear ujoints
3. Replace transmission mount
What are your thoughts? Am I missing anything in my thought process or am I going down the right path. My concern is that I can throw a lot of money at this and still no resolve the issue. Sorry about the long post, but I wanted to give you as much detail as I could. Thanks in advance.
1. Balance tires
