I am having serious problems with my 92. Just re-installed my new injectors, back from being tested. Got it to run pretty well for about 10 minutes, then shut off. Crank back up, and it barely idles. It pours white/gray smoke the whole mile home. Try to bleed injectors, all look free of air except for #1, which just spews foamy diesel, no matter how long I bleed it. I have a decent size leak from the return line right where it bolts to the tappet cover. Could an air intrusion cause an injector to leak fuel? I took apart the injector and cleaned to be sure, is in fine shape. Truck runs like it is down an injector, shakes badly.
