Decided to do this myself and got started last night. Going to work a little each night (probably 3 nights) to do this.
Last night I got it all torn down. Bearings out, axles out, ball joints pressed out. Tonight I'm going to swap the u-joints in the axles and begin to reassemble.
So far, it hasn't been bad. I read a ton of posts here before I started and I have a service manual. Best tip so far - heat on the caliper mounting bracket bolts. I tried one without for grins (not for long) and it was TIGHT..... a little heat and they came out easily.
I think that living in Texas has made it much easier for me than some folks. The bearings were not hard at all to pull. I loosened the bolts and tapped each with a hammer (and not that hard) to break them loose then I put the puller on and they came right out.
I am also doing the 08 steering upgrade while I have everything apart.
My question is this, does anyone know the pitman arm nut size? I forgot to check it last night and would like to make sure I'm covered there. I seem to recall it being fairly large.
Thanks!
Thanks!
