Folks, can you believe this? My Odo. just hit 3,080 miles and I developed the worst metal to metal rubbing sound coming from the front end I've ever heard! I thought it was coming from the upper or lower A-frame bushings... would you believe it's the left lower ball joint! Yup! DRY and no grease zerks!!!
Oh, the dealership will replace the ball joint but (get this) they have to take it out, inspect it to see if it IS worn and then ORDER the new one to match it.
Does that mean that if they think it's not worn they PUT IT BACT????
Even the Service Writer couldn't believe it!
This makes me wonder just how many other premature parts failures are out there??? And by the way... the DC OEM replacement doesn't have any grease zerks either!
White 2001, 3500, Auto,3:54 (soon to be 4:10),QC,2WD,LB,34' DBL slide Cardinal 5er
