Looking for first person recommendations for ball joint press accessories.
A recurring theme is to use 1/4” steel plate squares and a short iron pipe section with a rental press. The plates are simple enough, but I haven’t found dimensions on the pipe extension. ID, OD, and length of this cut pipe would be great.
Alternatively, the part number of an economical press accessory kit someone has actually used with a generic rental press would be helpful.
I’m putting EMF ball joints in the ‘06 Ram in my signature. They will replace the originals, which are wasted. Trying to save time by being as prepared as I can be before I start the work.
Thanks!
Thanks!
