In a few days I was going to replace my upper and lower ball joints. Then I found a TSB 02-04-96 Covers 1994-1996 BR ram trucks. It says the lower control arm ball joint ***. has to be replaced on the trucks with a Ball joint that is Tack welded which my truck is. This is a 2 wheel drive 1995 2500. The local parts store list a Moog K7205T joint for my truck but from what I have read the joint will not be tight enough when press in. Has any one run into this before and if I have to go that RT where can I find a lower control arm with ball joint other than the dealer. I don't know if they would even have it after 16 years. Just found this today.
