I had some front end damage the other day and my steering wheel no needs to be held a little to the left to go straight. I went to an alimnment place that suspects some minor frame damage needs to be fixed before bothering to align. The tech also said my upper ball joints are just out of tolerance and need to be replaced with offfset ones to fix camber.
SHoud I have these replaced or wait till they get worse and then replace with a bigger offset?
truck is an 03 with 57K on the clock.
The camber reads minus . 3 and minus . 4. he said tolerance is up to -. 3. Seems to me like it is close enough and I should wait and replace them as they worsen. What are your thoughts?
TIA, Dave
TIA, Dave
