Do the Fords have the same ball joint problems as we do?
LSchulz said:I don't know which ones will last longer given the same abuse, but the Ford ones are a lot easier to replace. I had an '02 F350 without a snow plow, and I did the ball joints on that around 100k. On that truck however, you can take the steering knuckle off, and the ball joints come with it. Then you can set up some blocking and get a good angle on them with a hammer, or put them in a press. It's a lot easier than trying to work under the wheel well.
CumminsPower98 said:My ball joints are doing well. If they are original to the axle (not original axle under truck) they have about 376k. I have personally put about 250k on them so they have well over 250k and they are still tight as ever. I did put zerks in the lowers quite a while back. Same mileage goes for the hub bearings. I recently added grease zerks to them also, which can be grease anytime without disabling anything.
JessePayne said:I would also be interested in finding out how to add fittings to lower ball joints and bearings. I just finished replacing my ball joints bearings and ujoints. I found greasable ujoints from Quad 4x4. Anything to make the rest of the setup last longer.
Gordon Maney said:How did you put grease fittings in the hubs and lower ball joints?
Schlickenmeyer said:at 110k and all the original balljoints. Guess I am lucky. not looking forward to them going though.
