I am kinda bummed, was just doing my 22,5K service and thought with all the talk about pre-mature ball joint failure I would check mine and sure enough they are bad at only 22456 miles.
No tire wear or drivability trouble yet, I hope they come out with a better joint for the replacement.
The way to check em is to lift the truck at the axle to where the tire is a few inches off the ground and then using a pry-bar between the tire and ground see if you can get some upward movement.
