Ball Joints
anyone have a 96 am/fm CD player
Heads up-new dually bed on E-Bay
Hey All
Been a while since my last post, I have a ? for you guys that have replaced your ball joints. I am going to have mine done real soon and I was woundering if there is an after market brand that is heavier duty then the stock ones. I have those 36" tires and thought I might upgrade the ball joints as well. There going out on me and are the OE ones with 65,000 miles.
Any help would be greatly appriciated,
Scott :D
Originally posted by BigBadDodge
Hey All
Been a while since my last post, I have a ? for you guys that have replaced your ball joints. I am going to have mine done real soon and I was woundering if there is an after market brand that is heavier duty then the stock ones. ...
I managed to last 90K miles 'til the lower left wore out with my 225/70-19. 5 Yokos.
Since you are Amsoil B2B, I might suggest using Moog parts and keeping them well-lubed with Amsoil Series 2K grease suited for the Bay State's climate. I honestly can't say I've ever met a Moog part I didn't like; they've always made a superb product. I must also say that I haven't needed any of their parts in ten years, and I don't know if their quality has changed in the meantime.
Of course, keeping them greased *could* be problematic, since the Zerk fitting for the upper joint might just contact the u-joint (if you have 4WD, which your sig doesn't indicate). The lower isn't a problem.
Fest3er
I replaced all four of mine at about 75k. Moog was recommended to me by a brake shop. I am very happy with them. They all come with grease zerks. Plugs are furnished to replace the uppers after you get them greased.
Shop around for a price. They aren't cheap but you can beat most of the auto supply shops. I found a good price at Warehouse Auto Parts of Redding, CA. They are on the web. I am sure there are other good deals as well.
I did the job myself and even though I had to buy a couple of large size sockets and wrenches, I saved money doing it.
If you do it yourself, be aware that you have to take the u-joints and axle shafts out. This is easy enough but extreme care must be taken not to damage the seals when you put them back.
Replacing the seals would be a real bear. Especially the one on the differential side.
Good luck.
Scott, I would second the Moogs from what I've seen. I think the 97 and 98 are the same, if so P/N K8607T is the lower and K8388T is the upper. Gary at Western Auto in Hanover got them for me and price wasn't too painful. Good Warranty!. I can't vouch is you can leave the zerk on the lower, its awful close the the axle—yes, mine are still in the box awaiting install!! I was figuring a right angle zerk might squeak by...
Thanks for the replies all,
Looks like I may go with the Moog's, I don't know why I didn't think of them to begin with. I already have a lot of moog steering componets, yes pricey, but I haven't had any roblems with there products either.
Thanks again for all of the great input,
Scott:D
