THess didn't say whether he has a 2WD or 4WD truck. The numbers are different.
My recent experience was replacing the upper and lower ball joints on a '96 2WD 3500.
A real big caution here.
The '96 and '97 lower ball joints are ALMOST the same, the '97 is 0. 010" larger where it presses into the A-arm. The early part is 1. 981" - 1. 985" and the later part is 1. 996" - 1. 999" diameter. This picture shows the splined area that is a different size. The smaller size part will slip into the larger sized A-arm without a tight press fit, so watch for this.
And just because you have a '94 - '96 doesn't mean you need the smaller part. A few years ago I had a '96 2WD 2500 and the dealer repaired a worn lower ball joint ... by replacing the A-arm! They told me the ball joint was riveted in - and I didn't know any better and paid them lots of bucks. I'm sure this ended up with a truck that had an early size joint on one side and a late size joint on the other side. In my just-completed repair of my '96 3500, both sides needed the '97 size part, so evidently both lower A-arms had been replaced earlier. They don't call the Dodge places "Stealers" for nothing!
My recent repair was done by
Enterprise Engine Performance and the ball joint labor was $280.
Watch your prices on the Moog joints, the later (larger) parts are almost twice the price of the early part.
I'm told that somewhere about 2000 or 2001 Dodge changed to bolt-in lower ball joints.
