I have a 99 2WD Dually. I recently noticed that the outer edges of the front tires are wearing faster than they should. So before the old girl goes in for an alignment I thought I should check for worn ball joints, tie rod ends, etc. Lucky for me everything was really tight, no slack at all. But there is a problem I have never seen before, all the ball joint rubber boots were crumbling and one of the lowers was completely missing (the rubber boot, not the ball joint LOL). I think the ball joints are originals because there are no grease zerks. I found replacement boots and ordered a set, should be no problem replacing them. If the joints had zerks, I would push excess grease through them to force out any grit that mat have gotten onto them. Would it be ok to just drill the top of the ball joint and add grease fittings?
