Hi folks,
I'm new to this Cummins game, but a old hand at all sorts of mods. I have a new to me 01 QC SB and have a idea I would like some feed back on. Can I use the same taped banjo bolt for the pump return line fitting(thicker) as the feed line? What I would like to do is first remount the driver side battery side ways and to the front witch would give me a space to the right side of it for 1) relocateing the fuel filter there and sending unit for the fuel pressure gauge.
I would like to come off the feed line banjo to a brass tee tied to the bottom of the sender. Uphill of the horazontal sender I would mount a nice aircraft fuel line ball valve that has 2 1/4" barbs at 90 degrees to each other.
This would be mounted to the tee. then take clear 1/4" fuel line and go from the ball valve to the second banjo in the return line.
Now I would mount a 3 way switch that breaks the power feed to the lift pump AND repowers it from a always hot source when you filp it up and down would return the lift pump to its normal wiring.
What this system would do is WHEN EVER you have air in the system, You simply open the ball valve at the gauge sending unit and flip the near by switch. Wait untill you see no more bubles racing through the clear line, shut down the switch and close the valve and your done.
That "bumpin the starter" thing sounds a little hokey to me although I'm sure thats been OK standard procedure. Routing the fuel line in a up hill fassion to the valve would ensure the sender has no bubles under it for jerky readings.
Well, what da ya think ? (aside from me having too much idle time)
