Since I've taken all banjo fittings out of my fuel supply equation, its easier for me to study them as time allows. Playing around with them this weekend I noticed something interesting. There are 5 bolts on a stock system. 4 are the same while the one at the VP44 is quite different. This is on a 1999 system.
The banjo bolt at the VP is shorter than the rest (no big deal) and only has 3 holes as opposed to 4 holes in the others. The holes are also centered around the circumference and are noticeably larger as shown in the photo.
The banjo fittings themselves are also not all the same. There are four equally sized fittings with the odd 5th being larger and located at the inlet of the Carter lift pump.
So what you may ask?? What does all this mean?? Well, I will show in a little while why the largest banjo fitting at the inlet of the lift pump is probably the worst of all.
Maybe... just maybe... those who offer aftermarket banjo bolts will change the way they make their replacements after they read my future posts here. Offering slightly larger holes isn't the best way to improve them. I think. You'll see what I mean later.
I'm obviously bored again as I'm starting another fuel supply thread.
The bolt on the left is the VP44 bolt (3 holes)... the right one is what the other 4 look like (4 holes).
