New to diesels, been turning wrenches on gas for awhile. I need to install some guages prior to some mild bombing... what in blazes are banjo bolts. I notice Geno's has some already threaded for installing a fuel pressure guage. Do I just need the one, or should I get the set with wider openings... does this help lube the injector pump? For guages I'm now thinking a Westach combo EGT/boost and a Westach fuel pressure in a piller mount.
Pros and Cons??? Does the Westach fuel pressure guage have a sender, or is diesel under pressure required to be plumbed into the cab? Also, any pros and cons on 1/4 vs 1/8 NPT... and what does NPT stand for??
Thanks in advance
Rodg in Bellevue
Thanks in advance
Rodg in Bellevue
