I just drilled out the lines between the pump and filter housing,they are restrictive,there are 2 of them,the best way to do this job is ,unbolt the filter housing,its only 2 10 mm head bolts,then unhook the hose clamp,or banjo from the back side of the filter housing,and unbolt the banjo from under the housing,or at the injection pump. unhook the 2 electrical sensors,drain the filter housing from the water separator lever into a bucket,and pop the whole housing right out,now you can get to the banjo's on the lift pump easy,without laying on your back. I bought the rays banjo's but if i had it to do over,id just drill them out. I used to have zero fule pressure on level 3 of the comp,couldnt use level 5. I added a carter booster pump,now i have no less than 5 psi on level 5,and 7 psi on level 3,where i had zero before.
