Banks-big head
How not to check the transmission fluid
IN NEED OF IMMEDIATE ASSISTANCE!!!! helllpppp
Can the Banks big head be purchased separately and will it work by itself or does it come as a part of system? Is there another manufacturer that offers the same? chris
chris sutton
1999 2500 qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & waiting for front ARB,
5" skyjacker lift w/ 35" BFG mud terrains on 16. 5x9. 75 Weld rims, black nerf bars, black bug persuader, lumber rack,
camel leather int. w/ mb quartz spkrs and 8" sub, power edge EZ, DTT vb, mag hy-tec transmission pan, red magview diff covers &
coming soon: DTT t/c, 275 injectors, L&L ladder bars & guages
Yes Chris, the Banks Big Head wastegate actuator can be purchased separately from any good Banks dealer. If you are unable to locate one, give Mike at The PowerShop a call at 1-800-835-8839. #ad
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass, Optima Yellow Tops, DD3s/DD Boost Module, Aeroquip AQP braided s/s fuel hoses, Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
John--thanks--I've already talked to him--I e-mailed Rob Hanson and he gave me the phhone # a couple of days ago---thanks again--chris
chris sutton
1999 2500 qcab longbed 4x4 red sport w/ all the options 'cept plow pkg, 4:10 detroit locker in rear & front ARB,
5" skyjacker lift w/ 35" BFG mud terrains on 16. 5x9. 75 Weld rims, black nerf bars, black bug persuader, black lumber rack,
camel leather int. w/ mb quartz spkrs and 8" sub, power edge EZ, DTT vb & tc, mag hy-tec transmission pan, red magview diff covers &
coming soon: 275 injectors, L&L ladder bars, tubo temp monitor & guages on "A" pillar
