Valve closes when engine cold to hasten warm-up, I gently tap accelerator when egt is about 400F and gate opens. Gate will not close when I'm on the road and let off power above 30mph, there's no ehaust breaking at all like on downhill etc. All HVAC gates open and close although cooling is warmer then it should be. Both started acting up at same time. All vac lines look ok, I'm wondering if the E-brake module is bad although it activates valve when engine cold . Unless valve is actuated when cold by a system other then E-brake module. E-brake is two years old, I leave it on full time. Banks not much help but did say might be the module. Cannister has 5yr. warranty but does not include module. Module was installed so far up behind dash and does not appear to have been secured, was rattling around till I velcroed it. I'd like to hear from anybody who has had a module fail and how it affected the E-brake etc. A $1,000. system should last longer I would think. Truck is 01, 2500 CTD, ext cab, Banks high ram, 4" pipe from turbo back. 285 Toyo's, 85K easy miles, some 5th wheel towing. Sorry bout the rambling, I just love my truck I guess.
Thank again.
Mike
Thank again.
Mike
