Anyone out there have an I-dash gauge? Any benefits over other gauges(edge, etc.)?
What sensor are you using on rear-end? I will need to add that to my 01 first, then to 17.I have the Edge CTS and really like it. In addition to the standard readings coming from the OBD II I have added oil pressure, transmission and rear end. It also gives me adjusted speed for my slightly larger tires. Only issue I have had is I'm getting a false reading from the rear end. I need to contact Edge to see what's up.
Thank you for the info.I'm pretty sure it is this one: https://edgeproducts.com/shop/eas-temperature-sensor-40f-to-300f-1-8in-npt
I'm pretty sure my Mag-Hytec has a pre-tapped hole for that. It'd be a good install when I change fluids next time.I'm pretty sure it is this one: https://edgeproducts.com/shop/eas-temperature-sensor-40f-to-300f-1-8in-npt
It sure does.I'm pretty sure my Mag-Hytec has a pre-tapped hole for that. It'd be a good install when I change fluids next time.
