This is my first time post. I have been a member for awhile and read the forums regularly. I installed a Banks Six Gun in my 04 Dodge 305hp. automatic. My only other upgrades are boost, egt, and transmission guages. I also have an AFT pro 7 installed. I went to the dyno after the initial install. The results were not good. I gained 15 hp on level 6 and not much torque. Called Banks and told them the problem. They had me check the resistance of the switch, I did and is ok. So I sent the tuner back to Banks. Thet sent me a new one. After install I hooked up my fifth wheel and made several runs on a hill. On the #1 position I had a top speed of 66 mph number 4 was 70 mph and number 6 was 72 mph. The egt and boost never increased above position 1 temps. My max boost was 23 and egt was 1200. I expected higher boost and egt. Also on same hill was cruising at 55 mph in # 1 position, selected # 6 and I gained 200 rpm and my speed was climbing through 60 mph before i had to get off the fwy. I called Banks again and they said check the wire harness, and if it is ok send the unit in for a refund.
My question is, arew these numbers correct or are they low. I expected more. Banks told me they had no numbers for my situation. Do I keep it or send it back?
