I scrapped the 15 and 30 degree silencer rings(problems at some rpms)and lost about 1/2 to 3/4 mpg, local driving and towing. I put the stock ring back in this summer and rechecked mpg. I put on a Banks Twin Ram a month ago and have checked my new mpg - one tank local driving and one tank towing with the stock ring so the only change was the Twin Ram. I filled up every time at the same pump, same spot and always up to the cap. Best mpg local was 19. 5 and towing was 14. 0 - before Twin Ram. Got 20. 9 local and 15. 8 towing after the Twin Ram. The towing included two very familiar test hills - one 4th gear hill and one 5th gear hill. The 4th gear hill is on SH24 westbound from Woodland Park, in the 'cone zone'. Before, I could do 67mph and after Twin Ram I did 69 at 2750 rpm and egt was only 1200 because I didn't have any more fuel - could stand to move the plate forward now to get it to pull to redline again. The 5th gear hill was northbound Monument Hill. Before I could do 87 over the first hump and 85 at the top. I did 90 over the first hump and had to slow down to 85 for traffic at the top - but it was doing it easily. I kept egt at 1300 or less for all the towing test hills. Some say they don't think the Twin Ram is worth the money for the improvement but I can tell you - with the proper air filter, exhaust and fueling it made a healthy difference on mine! It made more difference in power than changing from the 14 to the 16 housing and I gained on the low end power, lag and smoke with the Twin Ram rather than losing with the 16 housing. The improved power balance also made the engine run smooth as a sewing machine! I know it would be better to average mpg for several tanks but the 'before' mpgs I gave were the best I ever got for similar conditions. If I would have averaged all my 'before' mpgs, the averages would be less than what I posted. So I can safely say the Twin Ram was good for at least 1mpg on mine(probably more), so there will be a 'payback' with it! And believe me, Banks didn't pay me to do this!! Craig
