Ok I know that a engine is a giant air pump ,the more air in the more out. My question is this, I relize when you add a "programmer" like a Smarty it boosts the amount of fuel going in to the engine and adjusts the timing, ect... .
What does the amount of boost from the turbo do? If I have a relatively stock engine and and a 4 inch exhaust and a bigger intake, then put on a turbo that will produce more boost than the stock unit what could I expect.
Now lets be clear I am not talking about putting on a double or triple unit ,that would be used to pull sleds, I know that stronger head studs are needed for those applications. I don't know what a stock unit produces but what if I switched to a turbo that doubled it??? would I see a big increase in power?
