Was liiking under the hood of the All Mighty Cummins today and was wondering if anyone has made an attempt to put the battery where the BHAF currently is, looks like to me there is enough room only problem I see is not enough heigth. I was thinking that the sheet metal there could be cut out and then install a custom made dish or well to fit in the hole, then the batterie could sit in it. . I dont know if there is enough clearence between the sheet metal and the plastic wheel well but I bet there is.
If this could be done than we could straighten the 4"hose out and put the BHAF in the corner where the battery was, It has to be cooler there,think of this the moter runs 200 and the turbo is way hotter and the outside air is say 100 so we loose 100 degrees right there,I run a temp to the cab from my air horn and on a 100 degree day it will run around 125 but not any hotter,acording to every thing I have learnrd about air exchangers the best you can ever do 100% efficiency you can get ambient +20 so that tells me that our intercooler is a very efficient piece of equiptment . currently the filters in the hottest part of the compartment , this move would certainly help to lower EGT and a guy could then build some kinda ram air off the front for cooler air ? Just a thought... ... ... ... Kevin
