Battery Blankets & Pan Warmer
Garage Air Compressor
Portable Sandblaster
Looking at Kats Battery Wraps and oil Pan Warmer
Do these 3 items draw enough amperage to overload ONE Extension Cord? I couldn't find amp draw on the website.
What's the THIRD item?? The oem block heater??
We have the OEM style block heater installed on my Sons truck and I must say CONGRATULATIONS to Geno's for a nice product that FITS LIKE IT SHOULD. The 3 products are 2 battery blankets and the pan heat-pad = 3
The OEM block heater will be on its own cord
What ever you do use the proper size extension cord. Most grocery cords are 16 gauge.
One plug will be fine. This is how I rig mine up. Get a Marinco with an attached rubber plug if you live in a place where they salt the roads or use chemicals.
I wouldnt put anything else on the same breaker as the block heater.
I'd allocate 15 amps for that alone. Especially if you have a long run and/or thin extension wire...
jm.02
