I have a 96 Ram with the CTD and lately I have noticed the water appears to be boiling out of one or more cells on the neg side of the bat. on both battery's. My ampmetter shows that the altenator is only charging 14 volts,I have checked the cells with an hydrometer and it reads good. I know that the chargeing system feeds through the A. S. R. and the Battery temp sensor through the PCM. Does anyone have any idea's on what chould be the cause? 1996 Ext Cab,Auto,4x2,Red,Egr,Trans Temp,Boost Gauge,TST #8,3. 54,87,000 Miles
------------------Well here is what I found,the battery temp sensor checked out good, so I bent the contacts in the connector a little to make better contact and put every thing back to geather,then I took the truck for a drive(60 miles) and found that the charging system was no longer over charging any more. When you have acid boiling out of your battery,it is an over charge condition and will damage the bat. If you feel the sides of you battery and they feel like they bulge, that is caused by over charge. The negitive bat post was getting so hot that it melted the plastic wrap around the positive cable. Thanks for your help and sorry it took solong to repley, I siged up with a new internet provider.
[This message has been edited by BillTanziniSr (edited 09-21-2000). ]
