Hi, I have a question. Why does the service manual say to disconect the battery when replaceing the flasher/relay ? The reason I ask is this. I have a 98. 5 24 valve and a service body on it. The tail lights on the service body are standard round truck light mounted in rubber. I replaced them with LED. This is not just a 1157 bulb replacement. Mine have about 15 LEDs inside of the sealed unit.
Everything was fine after replaceing for about a week then I hooked up to my trailer and towed for a day. After disconnecting my flasher flashes at twise the rate on both sides (No bulbs out) I read on the boards about our special flasher/relay and how it senses low resistance as a bulb out and flashes fast. I understand the LEDs are low resistance. So, I looked up the flasher in the SM and it says to disconect the battery first. Why?
Is this reseting a computer somehow? Will I be able to run the LEDs with this flasher?
Thanks for any help
Thanks for any help
