battery help
Missing/Surging - What's Wrong?
Looking for Shutdown Solenoid$$$$
got a 95 auto 2x4 i changed batteries on, and the abs went haywire can anyone tell me why
hooked batterys up correctly, and changed both at one time, used me and another guy to pull positives at the same time
dealer says you can only disconnsect one battery at a time?????????????????//
help please
thanks Brandon Fenley
Check your fuses. My brake light fuse blue which caused the same symptoms.
95 CC 4x4 3. 54 Laramie SLT Driftwood/green,Tint, Gemtop Cap, Dodge bed liner, mud flaps,
Geno EGT/Boost, TST #6, Auto Trans, 57K miles,(I don't get out much),
265x16 coopers, DeeZee Rboards, K&N Airfilter.
Brandon
I would check your fuses like rosebunch said. If a sensor is s bad in the ABS system the light will come on. I have never heard there was a problem with disconnecting both batteries at once. I have always done mine 1 at a time. I had no other choice being alone.
Brandon,
I have removed the batteries from both my 1995 and my 2000 pickups more than once. I have had just one out, and I have removed both at the same time, leaving the truck dead. I have never had the problem you described. I doubt that it is anything you did with the batteries that caused it. I would also suspect a fuse, but if it's not that, I'm no help.
Loren
Before I replaced my batteries they went dead several times and I used a charger to start the truck,every time the ABS light came on afterwards,but the brakes worked fine. Light always went out after I stopped then restarted the truck. Same thing happened for the last time when I replaced the batteries.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
[This message has been edited by illflem (edited 02-09-2001). ]
help please
I just replaced my driver side battery and my ABS and brake lights come on after driving about 25 feet. All fuses and wires look fine. I cleaned my speed sensor but did not test with meter. Speedometer works fine. Any solution?
wow this is an old thread... ..... I just solved the problem with a scanner finnally and went on with life... ..... kinda nice having rapid access to a scanner
cant remember the code now
