Merek, the Hellroaring battery isolator is definitely the
best way to go. It is solid state (reliable) and with the FET technology, they have virtually eliminated all diode voltage drops and heating. The only advantage to the solenoid switch is a very low price in comparison. So far, I have had no troubles with the solenoid switch.
There's really nothing tricky about my ammeter set-up. It is basically just a voltmeter that measures the slight voltage drop across the inline shunt resistor (this is the method that most ammeters use). By using a . 01-ohm shunt, I drop 0. 1V for every 10-amps that flows. I programmed the ammeter (voltmeter) to slide the decimal over two places so it reads 10. 0 as well rather than 0. 10. As the batteries are charged, the current is reduced thus the voltage drop diminishes to a negligeable amount. These type of voltmeters can by purchased at almost any electronics store. I got mine at
http://www.datel.com. Also, make sure that the wattage of the shunt accomidates the amperage that you can potentially pull. A 100-watt shunt is good up to 100-amps.
Lastly, I connected my shunt on the return (ground) line rather than the battery supply line. This shows the total sum of all voltages being used. Remember, there are several power lines going into the camper (blinkers, lights, etc. ), but only one return coming out. I then have a clear indication that my turn signals, etc. are working as well as the battery charging.
P. S. As an afterthought, I ran a twisted pair (sense leads) from the shunt to the ammeter for better noise immunity.
