See if you can get your hands on an oxyacetylene torch. I use it at work to heat up the elbow, not the bolt, when the bolts get that stubborned. Otherwise, you can cut the housing carefully in three different places near the bolt and use a chisel to knock the pieces out so that the bolt is freed. The second one is really limited to available tools and available space. The other thing you could try is to tighten it a bit and then try loosening it. Cursing helps. Happy New Year.
