BD brake killing engine
Finally Got Some Big Wheels
PICs of you 3500 with a topper on it
On my recent camping trip with the camper loaded, I was backing into the site and as I hit the pedal, the engine almost stalled. This happened two times. I decided to shut off the BD brake and the problem went away. I was only 50 miles from home and I didn't really work the engine that much. The altitude was around 2000' and the air temp was around 85F. Since the brake is OFF (below 28MPH), I don't understand why the engine was stumbling. It never did this before.
Anyone have any clues?
:confused:
Mine does the same thing in reverse. I think its because of the high reverse gearing especially if you get on the throttle and get off in a hurry... like you do backing the trailer onto leveling blocks. You can easily go 30 in R. :eek:
-Paul R. Haller-
Red 1t you said that the brake is off under 28 mph if so how is possible to warm up eng at zero speed ? not tring to stir up any thing just a thought . :confused: Ron in Louisville KY:rolleyes: :D
